Enables NTP on a VLAN.
enable | Enables NTP on a VLAN. |
vlan-name | Specifies the name of a particular VLAN on which to enable or disable NTP. |
all | Enables or disables NTP on all VLANs. |
vr | Specifies setting up NTP on a VR. |
vr_name | Specifies the VR name to enable NTP on. If a VR name is not specified, the VR of current command context is used. |
NTP is disabled on all VLANs by default.
N/A.
The following command enables NTP on a VLAN named “Southwest”:
enable ntp vlan Southwest
This command was first available in ExtremeXOS 12.7.
The vr option was added in ExtremeXOS 22.2
